When I try to delete the old device type, I get the “DeviceType still in use by devices” message. Problem is…nothing is using that device type! Is there a way to forcibly remove this old device type that I’m not using? I’ve got quite a few automations hooked into the device (that isn’t using this old device type), so deleting the device and re-adding isn’t a solution for me.
In the IDE device handlers section, in the last column ‘sessions’ there’ll probably be a session showing for that dth, close that and you should then be able to delete it.
I have this issue. I set up a custom DH on a virtual device to check it out. I’ve deleted the device, but it still says a session is active so I cannot delete the DH. Anyone know how to clear this?
I honestly don’t remember. I have so many custom DH’s that it could be any one of them. It could also be none and I may have actually gotten rid of it at some point. Also possible that it just finally disappeared on it’s own!
I just opened a ticket on this problem because I have a custom DTH I added 3 years ago that I cannot remove. I stopped using the custom DTH at least 2 years ago!
(Support request #938284)
