Developer Workspace - Project disappeared
Hi all, I’m coming back after a year of inactivity to work on a smartapp I developed. I log into the Developer Workspace and there are no projects listed there.
The smartapp which I deployed is still visible in my Smartthings app on my phone in the same place - under the Discover menu. And it appears to be mostly functioning.
How can I get back the project in the Workspace so I can do debugging etc, make changes to the server URL or anything else?
Hi, @Lev
1- Could you provide support access to your account, please?
  3. Go to the SmartThings Web (my.smartthings.com )
  4. Log in to your Samsung Account
  5. Select Menu (⋮) and choose Settings
  6. Toggle on Account Data Access
  7. Select the time period and confirm - In this step, please select “Until turned off”, once the team finishes, we’ll let you know so you can disable it again.
2- Could you share a screenshot of the projects view please?
3- Do you have more than one workspace in your account?
Hi @Itati, thanks for helping. Support access is enabled.
Hi, @Lev
Could you please confirm this information so we can follow up?
  1. Could you share a screenshot of the projects view, please?
  2. Do you have more than one workspace in your account?
Hi @Itati,
Thanks.
I don’t have more than one workspace in my account.
I have not enrolled my organization, it was just one private workspace.
Hi @Lev
You can work on your projects from the API; we saw that it does appear. If you need to create a new application, you can do so from the Workspace. However, if you want to use the same project, you can edit it directly from the API.
