I was testing a ‘Schema Connector’ in ‘SmartThings Developer Workspace’(=DevWS)
I accidentally deleted the viper endpoint app with the smartthings CLI with the following command,
$ smartthings schema:delete 1
which made the project in the DevWS orphan.
This was my mistake.
But the problem is,
I coudn’t remove the orphan ‘schema connector’ project in the DevWS.
When I try to delete the project, it throws the error message as below, and never gets deleted.
I hope orphan ‘schema connector’ project could be deleted in DevWS, even if the endpoint app does not exist.
Thank you.
