I have three zigbee sensors that I would like to get to work with Smartthings, one temp sensor, one co2 sensor and one motion detector. Would anyone like to help out getting these to work in ST?
Hi, i recommend sharing a bit more about these sensors. Brand, Protocol used etc.
As a first step you can check in live logging in the IDE if they are recognized by the HUB when you try pairing them.
You should be able to see the Zigbee Fingerprint, with it you should be able to create your own device type if the existing ones do not work already.
Take a look at the Xiaomi Zigbee Thread for pointers
