Dashboard, Tiles and Hello Home issues
My dashboard is not refreshing and tiles are not refreshing also my Hello home did not trigger this morning, is ST experiencing issues?
All good in the hood here
I’m having the same issue. If I’m in the iOS app bouncing around from screen to scree, when I go back tot he things screen it does not load. If I force the app closed and then re-open it, it comes up fine. I think this is a bug in the latest version of the app since I can get it to happen on multiple devices on multiple networks (different WiFi, cellular, different logins).
Once I get a few minutes, i’m going to submit a ticket to support about it.
Yesterday & today I received several of the “failed to load dashboard” errors. I’m on iOS as well & I see the spinner wheel way more than I see my actual tiles.
I upgraded to SmartTiles 5.2 using GitHub. It has not shown up yet on my phone. Do I need to delete 5.1.1 first? Or can both exist on the phone at the same time? Or will 5.2 automatically delete 5.1.1? Anybody know?
You should be able to keep both versions on your phone. I still do that. As for not seeing version 5.2 on your phone, make sure you publish it “for me”, so that it will show up on your phone.
I had done that. My problem was I did not “import” it from My Apps. However, now I have it in but it is giving me An Unexpected Error Occurred and won’t make the URL for me. The same thing happened on 5.1 for a day. I think it will work later on.
Things seem normal now.
