Dasboard or Smart App?
How can I make smart sense temperature sensor send me an alert text (android) when temp gets close to freezing. Say 35 degrees?
Here’s a SmartApp I wrote that should be able to do what you want:
You can do it in Rule machine as well.
You can do it right in Smart Home Monitor using custom.
Thank you for taking the time to respond. Will check out your app.
Hapster
Thanks for your tip.
Hapster
Sounds like an easy solution. Thank you for your response.
Hapster
[quote=“Hapster, post:1, topic:37747, full:true”]
[/quote]Here’s another app that can do this along with some other things you may find useful.
