I noticed after updating the Android App, but this was shortly after a hub update also.
In full disclosure - we havenāt put the UK versions of Danalock through device certification (hence why they are not on https://www.smartthings.com/uk/compatible-products/). The breakdown is somewhere between the polling and DTH, but I am not sure the details. I do not a timeline (and couldnāt tell you if I did) for device certification. In the meantime, there is template code for the DTH available in the IDE that you may have success tinkering with.
My Danalock 125BTZE was working perfectly fine until the recent FW update⦠now after about 12h the danalock does not respond anymore, and in the live logging, only polling events show up. After restartĆng the hub everything works fine again for some hours. Any idea what this is?
I tried and the lock works correct with the default Z-Wave lock device type. State change is displayed immediately in ST app regardelss how is modified: pressing the button on lock, rotating the lock manually or using the key.
Can I ask, are you able to detect when a user unlocks using bluetooth and identify the user with this lock?
Where would I look for this information? There is only one user, me.
Itās confusing but the BTZE is a Bluetooth + EU Z-Wave model, where the BT is Bluetooth only (hence why it works with SmartThings)
Sorry if my question is unclear.
If you unlock using Bluetooth on your phone are there any events in smartthings to indicate who or what has unlocked the door? Could I potentially use this event to identify the user?
Just thought Iād see if there has been any change in this? Did you guys get these issues sorted out? Iām considering picking one up
This DH works with the lock (Z-Wave part) including advanced features like Audio/Notification and AutoLock:
EDIT: See the different models
V2 BTZE: BLE and Z-Wave EU freq (works with ST Hub using EU Freq)
V2 BTZU: BLE and Z-Wave US freq (works with ST Hub using US freq)
V2 BT: BT Bluetooth Smart (no z-wave functionality)
Thanks @RBoy
Have you bought Danalock V2. Is the status indeed updated in ST, even if you open it using keys? Does it work reliable for you?
