Custom Edge driver installed but Lua code never executes - no logcat output
Hi,
I have created a simple custom Z-Wave Edge driver for a Qubino ZMNHOD1 (Flush Shutter DC). The driver uploads and installs successfully, the device shows the correct driver ID, but the Lua code never executes.
Even a minimal driver with just log.info("MINIMAL DRIVER LOADED") at module level produces nothing in logcat.
The driver is on a private channel that the hub is enrolled in.
What I have tried:
  • Multiple driver versions and package keys
  • Unenroll and re-enroll hub from channel
  • Exclude and re-include the Z-Wave device
  • Power cycle the hub
  • Logcat with and without --hub-address
  • Location mode change to force auth resync
Logcat behavior:
  • Connects successfully and shows output from all other drivers (Zigbee Switch, frient Contact, Z-Wave Switch etc.)
  • Zero output from my custom driver, even during driver install or device switch
Hub: SmartThings V3, firmware 000.060.00012, hub app 1.0.49-13
Has anyone seen this before? Is there something on the SmartThings backend that needs to be reset?
One word: fingerprints.yml
You won’t see anything before the driver is actually loaded when the fingerprint matches.
Can you please paste the important parts of your driver (fingerprints.yml, init.lua, profile, …)?
fingerprints.yaml:
zwaveManufacturer:
  - id: "Qubino_ZMNHOD1"
    deviceLabel: "Qubino Flush Shutter DC"
    manufacturerId: 0x0159
    productType: 0x0003
    productId: 0x0053
    deviceProfileName: plant-selector-v2
init.lua:
local Driver = require "st.zwave.driver"
local capabilities = require "st.capabilities"
local log = require "log"
local driver = Driver("qubino-plant-valve", {
  supported_capabilities = { capabilities.switch }
driver:run()init.lua:
lualocal Driver = require "st.zwave.driver"
driver:run()
profiles/plant-selector.yaml:
components:
  - id: main
    capabilities:
      - id: switch
        version: 1
config.yaml:
packageKey: qubino-valve-v2
version: 1
dependencies:
  - st
profiles:
  - plant-selector-v2
The device is currently assigned to the driver using edge:drivers:switch manually, and the device’s manufacturer code matches the fingerprint (0159-0003-0053).
Is this AI generated or copy & paste error?
This is the bare minimum to get a log output:
local function device_init(driver, device)
  log.info("Device initialized: " .. device.id)
end
  supported_capabilities = { capabilities.switch },
  lifecycle_handlers = {
    init = device_init,
driver:run()
You need permissions to config.yaml file
Instructions here:
This is how a config.yml typically looks like:
No dependencies, no profiles.
files are stripped down in order to isolate the problem. However, I have used AI in an attempt to find a solution.
Hi,
This device is already included in the SmartThings Z-Wave Window Treatment driver:
Because of that, the existing driver should already support the device’s standard functionality. If you’re looking to add custom functionality or modify its behavior, you can use this driver as a reference/example and build your own custom Edge driver based on it.
Thank you all for the reply, it was very helpful.
