@nayelyz Looking for your help once again. I know we spoke earlier about isComponent=true child devices, but today’s question is about the isComponent=false variety. The child is displayed on the dashboard but remains in the offline state, everything grayed out.
I have no problem creating the child device. From the parent, I can sendEvent to the child for attribute “switch”. I know this is working because the I see it in the child event log and if the parent interrogates the child, the new value is returned. All Good. For the child DTH I created a deviceConfig listing just the switch capability. After creating this I added the vid: into the child and saved it. The child shows the controls you would expect for a switch capability, but the switch state shows the cloud icon instead of the on/off state. I will include the child DTH code and the device presentation.
- Switch Child Device
metadata {
definition (name: “Switch Child Device”, namespace: “futuredance12594”, “vid”: “e92cc1cb-5184-3238-9f49-8703c5d748be”, “mnmn”: “SmartThingsCommunity”) {
capability “Switch”
capability “Refresh”
capability “Configuration”
preferences {
input “poolSpa1”, “enum”, title: “Pool or Spa”,
options:[[0:“Pool”],
[1:“Spa”],
[2:“Both”]]
def updated() {
log.debug("----- updated()")
sendEvent(name: “switch”, value: “off”, displayed: true, descriptionText:“Initial Value”)
def List configure() {
log.debug("----- configure()")
sendEvent(name: “switch”, value: “on”, displayed: true, descriptionText:“Initial Value”)
void on() {
log.debug("----- on()")
parent.childOn(device.deviceNetworkId)
void off() {
log.debug("----- off()")
parent.childOff(device.deviceNetworkId)
void refresh() {
log.debug("----- refresh()")
parent.childRefresh(device.deviceNetworkId)
and the Device config JSON:
"dashboard": {
"states": [
"component": "main",
"capability": "switch",
"version": 1,
"values": [],
"patch": []
"actions": [
"version": 1,
"values": [],
"patch": []
"detailView": [
"version": 1,
"values": [],
"patch": []
"automation": {
"conditions": [
"version": 1,
"values": [],
"patch": []
"actions": [
"version": 1,
"values": [],
"patch": []
"type": "dth"
The preferences in the child are merely to enable the Settings menu.
and the parent’s child creation:
addChildDevice(namespace=“futuredance12594”,DTH Name=“Switch Child Device”, dni=“37-ep1”, hubId=null,properties=[completedSetup: true, label: “Pool Control - Switch 1”,isComponent: false, componentName: “ep1”, componentLabel: “Pool Control - Switch 1”]
This worked fine in the Legacy App. I’ve done all the usual cache reset tricks and waited days, but no change. I have another child which uses the thermostat capability which has the same issue, correct controls for a thermostat capability, but all disabled. Hopefully the same fix will apply to both.
Any ideas?
Keith
