Cannot make Device Type Handler components made with custom capabilities!
After processing Create New DTH in IDE, when we enter the following cli using the ID of the DTH, we get deviceConfig.json, right?
CLI:
$ smartthings presentation:device-config:generate “SECRET_ID” --dth -j -o=deviceConfig.json
deviceConfig.json
"type": "dth",
"dashboard": {
    "states": [
            "component": "main",
            "capability": "switch",
            "version": 1,
            "values": [],
            "patch": []
            "capability": " TOP_SECRET_CAPABILITY1",
            "version": 1,
            "values": [],
            "patch": []
            "capability": " TOP_SECRET_CAPABILITY2",
            "version": 1,
            "values": [],
            "patch": []
    "actions": [
            "version": 1,
            "values": [],
            "patch": []
            "version": 1,
            "values": [],
            "patch": []
            "version": 1,
            "values": [],
            "patch": []
"detailView": [
        "version": 1,
        "values": [],
        "patch": []
        "version": 1,
        "values": [],
        "patch": []
        "version": 1,
        "values": [],
        "patch": []
        "capability": " TOP_SECRET_CAPABILITY3",
        "version": 1,
        "values": [],
        "patch": []
        "capability": " TOP_SECRET_CAPABILITY4",
        "version": 1,
        "values": [],
        "patch": []
        "capability": " TOP_SECRET_CAPABILITY5",
        "version": 1,
        "values": [],
        "patch": []
        "capability": "TOP_SECRET_CAPABILITY6",
        "version": 1,
        "values": [],
        "patch": []
"automation": {
    "conditions": [
You don’t need to read all deviceConfig.json! Below is an estimate of the results.
If you use the following command using this deviceConfig.json file, a vvid appears, and then applying this vvid to DTH creates the UI we want to create, right?
$ smartthings presentation:device-config:create -j -i=deviceConfig.json
But what I want to do is make it like this. (Bringing capabilities into components)
For this, you just need to set component for each capability of deviceConfig.json, right?
When I did that, the question was no. Is there any way to do this? What am I missing?
Waiting for your answer, I will work hard to develop it… Thank you
Hi there!
Can you give more details about the device are you trying to integrate, please? For example:
  • Type (Zigbee, Z-Wave, C2C, etc.)
  • Model, eg. Is this a device you bought? Such as a smart bulb (LIFX, Philips Hue, etc.)
Also related to this post:
