I have finally found the full guide on how to develop a driver, it is quite difficult, but not impossible, I suppose, unless the lua code below is very close ti being right, I have a lot of testing work to do.
local capabilities = require('st.capabilities')
local Driver = require('st.driver')
local log = require('st.log')
local json = require('dkjson')
local cosock = require('cosock')
local http = cosock.asyncify('socket.http')
local ltn12 = require('ltn12')
-- Device configuration
local REFRESH_INTERVAL = 300 -- 5 minutes
-- Bridge communication functions
local function build_bridge_url(device)
local addr = device.preferences.bridgeAddress or 'localhost'
local port = device.preferences.bridgePort or 5000
return string.format('http://%s:%s', addr, port)
end
local function make_request(device, path, method)
local url = build_bridge_url(device) .. path
local response_body = {}
local success, code = http.request{
url = url,
method = method or 'GET',
sink = ltn12.sink.table(response_body),
headers = {
['Content-Type'] = 'application/json',
if success and code == 200 then
local body = table.concat(response_body)
local decoded = json.decode(body)
return decoded
else
log.error(string.format('[%s] Request failed: %s, code: %s', device.label, url, code))
return nil
end
end
-- Device status update
local function update_device_status(device, status)
if status.battery then
-- Convert voltage to percentage (assuming 6V max, 3.5V min)
local battery_pct = math.floor(((status.battery - 3.5) / 2.5) * 100)
battery_pct = math.max(0, math.min(100, battery_pct))
device:emit_event(capabilities.battery.battery(battery_pct))
end
if status.connected ~= nil then
if status.connected then
device:online()
else
device:offline()
end
end
if status.food_low ~= nil then
device:emit_event(capabilities.switch.switch.off())
end
end
-- Capability handlers
local function handle_refresh(driver, device)
log.info(string.format('[%s] Refreshing device status', device.label))
local status = make_request(device, '/status/' .. device.device_network_id)
if status then
end
end
local function handle_feed(driver, device)
log.info(string.format('[%s] Manual feed triggered', device.label))
-- Get portion size from preferences
local portions = device.preferences.portionSize or 1
local result = make_request(
device,
string.format('/feed/%s?portions=%d', device.device_network_id, portions),
'POST'
if result and result.status == 'success' then
-- Emit temporary "on" state
device:emit_event(capabilities.switch.switch.on())
-- Schedule switch to turn off after 2 seconds
device.thread:call_with_delay(2, function()
end)
-- Refresh status after feeding
device.thread:call_with_delay(5, function()
end)
end
end
-- Lifecycle handlers
local function device_init(driver, device)
log.info(string.format('[%s] Initializing device', device.label))
-- Set initial state
-- Initial refresh
-- Schedule regular updates
device.thread:call_on_schedule(
REFRESH_INTERVAL,
function()
end
end
local function device_added(driver, device)
log.info(string.format('[%s] Adding device', device.label))
end
local function device_doconfigure(driver, device)
log.info(string.format('[%s] Configuring device', device.label))
-- Validate bridge connection
if status then
device:online()
return true
end
return false
end
-- Driver definition
local driver = Driver('PetSafe-Feeder', {
discovery = nil, -- Manual device addition only
lifecycle_handlers = {
init = device_init,
added = device_added,
doConfigure = device_doconfigure,
capability_handlers = {
[capabilities.refresh.ID] = {
[capabilities.refresh.commands.refresh.NAME] = handle_refresh,
[capabilities.switch.ID] = {
[capabilities.switch.commands.on.NAME] = handle_feed,
log.info('Starting PetSafe Feeder driver')
driver:run()
