ny_robert
(Rob B)
1
Hi All, I’m trying to create an automation between a specific time and sunrise/sunset
(If motion is detected between 11pm and sunrise; turn on light)
I seems you have to select 2 specific times or between sunrise and sunset. Any workarounds to do this? Thanks
jkp
2
ask in the following thread if you can use the calendar functions to achieve the time(11pm) to sunrise using their Edge Driver.
Hi @ny_robert
It can’t be done with automation.
If your region has access to smartligting app you can use it and it will not disappear with groovy
eric182
(Eman ym)
4
I have asked for this function a few times. Having a set time to sunrise or from sunset to a certain time.
@nayelyz
ny_robert
(Rob B)
5
Thanks for confirming @Mariano_Colmenarejo & @eric182
I’ve created a work around by adding a virtual switch that turns on/off based on sunset/sunrise and included it in my if statement.
Example:
If it’s between 11PM & 8AM (choose an end time that will always be after sunrise)
and virtual switch is off
Then turn on light
A clunky way to do it but it works, so far
jkp
6
what time frame is used for night in location mode?
ny_robert
(Rob B)
7
For me night time starts at 10 pm and ends 1 hour before sunrise
