i just installed your App and it works. I wish it had the sunset/sunrise time offset. your add feature isn’t very useful to me as i already have been using smart lighting to turn on certain lights indoors and outdoors, but skill is a nice option.
Hi, does this not work for z wave devices? When I try to select switches none of the z wave switches are shown.
I assume you are using the classic ST app, correct?
You need to configure in settings which switches VLD is allowed to use.
After that, may need you to private message with more specific information.
I have not seen any issue as you describe.
HI,
Thanks for responding. After messing with the app and the online site all night and into the early am I think I figured it out and it was basically enduser error, or me being a noob to smartthings and the way to install apps.
How do you install the app ?
In the ST IDE, you need to install the code. Search the forum here for installing custom SmartApps.
Then once the code is installed in the IDE, you use the classic ST mobile app to enable the app and to put in the settings.
