Didnt monitor this afternoon and I am mow able to see the scheduler timers associated with the invoking statement - all I have asked for. Awesome - blown away - donated cheers!!! Keep the good stuff coming.
After posting this in the wrong thread, here goes:
Okay, hereās the BIG news. v0.0.061.20160602 - Alpha test version - Minor bug fixes. Introducing the Follow-Up piston. Chain them together, delay them forever, do whatever you need with them
Follow-Up pistons are just like the Simple pistons. The only differences are:
- does not support triggers
- does not subscribe to anything
They can be initiated from other pistons via the Follow up with piston task. This task can be delayed just like any other using the Wait task in front of it, so you can technically say "IF (this) Then (that) Else (wait 5 min, follow up with piston).
Even better, you can follow up with the piston over and over⦠the follow up piston can follow up with another piston, even itself. Combine that with a global variable counter and you can have a complex solution where something initiates the counter, does things and follows up with a piston that can follow up with itself x times until either your expectations are met, or the counter hits 0, hence giving up⦠I guess, unlimited possibilities
Enjoy.
Thank you
Where would one donate? Iād love to show my appreciationā¦
When I get to my phone, Ill be donating too!
Thanks for adding the dashboard, it works great.
Do you think at some point you might be able to add a formatting option for variables?
Examples:
{someDate:MM/dd/yyyy}
{someDecimal:#}
{anotherDecimal:#,##0.00}
LOL - Iād have to invent God Mode for that⦠way beyond expert
UPDATE: I should call this the my-momma-is-an-expert-and-Iām-better-than-her mode.
Bam! Done. Use v0.0.061 LOL - I am so happy I decided to go with hexadecimal, or else Iād be running out of numbers 000-999⦠LOL Chrome and Firefox are eating dustā¦
Follow up to this. When I create a new piston and hit āDoneā, it goes back to the CoRE āhomeā page and not to the SmartApps page. And eventually the new piston shows up in the list, so that appears to function as expected. Itās only when you tap āDoneā on an existing piston that it skips back over the āhomeā page to the SmartApps page.
I gave this a shot and received āYou cannot currently add thisā I believe it was.
What canāt you add? Hold on, making some changes to the follow up. Will allow any piston, ask for delay, and possibility to return resulting piston state to a variable. Also adding Execute piston which would not have the delay. Also, follow-up pistons should not schedule time events. It does as of now, bug.
[quote=āchickwebb, post:2487, topic:46546ā]
[/quote]Just to add my $.02⦠I am certain this was new behavior, beginning roughly 7-10 days ago.
Iāll look into it. Got an Android tablet that acts like that.
Meanwhile, updated the Follow Up to have a delay and a variable too. So if anyone used that, please revisit that task.
Also added Execute piston (which does an immediate execution on the piston and can return the new state)
v0.0.062.20160602 - Alpha test version - Updated Follow Up and added Execute. Not fully tested yet.
Hey guys what would be the best way to create a piston that will wait for my lock to be unlocked for at least 5 minutes before triggering any actions?
You can start with a conditionā¦
If lock is locked then
Using devices
Wait 5 minutes
Do stuff
Cancel on piston state change
Thanks for the quick fix. Looks good on my end. But my end goal of triggering on global variables may not be necessary with the new āFollow-upā pistons. Iām still playing around with those.
Thank you @ady624 I knew I was missing something!
This:
You need to update the code. And itās probably saying that because it was (at first) only allowing Follow-Up pistons and you havenāt yet created any. The latest version allows you to āexecuteā any piston. Execute is immediate, whereas Follow Up allows for a time delay (built-in wait). Also, the āFollow-Upā pistons never run on their own, only when executed by other pistons.
Gotcha!
So, if the follow up piston does not need to function seperately (other than to have seperate on / off selectability) than is it safe to say it no longer needs itās own trigger?..only that of the lead app?
Hope that made sense.
