Looking for a way to control the lights of my andon. I looked into RGBetc controllers and it seems none of them will allow control of each channel simultaneously. I need it to be cloud service free. I’m going to give this Homeseer HS-WX300 a shot. It has indicators built in but my andon dream is starting to fade. Thanks for looking.
Something like the Zooz ZEN31 RGBW Controller might be a more appropriate choice. The Homeseer device you indicated may have RGB LEDs, but they are just for use as an annunciator. That device is a simple dimmer/switch for use with any dimmable lamp.
Well that worked. Now I want edge drivers, consolidate all the switches under one device and two more channels. Otherwise, I’m pleased as peaches. it was as simple as adding the device via QR code and adding the conditions for on and off.
If “another solution” means getting more than the ZEN31’s four channels while keeping it local, I’d try two ZEN31s and group them in SmartThings rather than expecting one controller to do everything. I’m not aware of a stock Edge driver that merges multiple ZEN31s into one tile; a virtual device plus routines is the usual workaround. If you mean replacing the ZEN31 entirely, what’s falling short—channel count, Edge driver support, or the Andon behavior?
