Same time? No. Close to it. Potentially. Right now ST doesn’t have scenes so it will have to relay each command to dim or set color to each device from cloud to hub to device. So there will be lag.
However, it is possible. How do you plan to control this though? Physical switch, UI in mobile app?
I have the same set up and have the same need. Unfortunately, the smart app out there that I think @twack wrote that syncs dimmers does not dim Fibaro let alone coordinate colors.
Looks like I got the same as you except RGBW. I have ten Fibaro RGBW controllers and sized transformers based on length of strip. I built three custom light fixtures using white LED. I still have other things I would like to do with this controller such as a dimmer panel, sound synch and local switch. It is such a powerful controller and the existing device type just scratches the surface.
I have the Fibaro only drive LED strips. I have TPC and GE Link bulbs and am trying to get an Aeon RGBW Z-Wave bulb paired. I returned Hue a while ago because my wife didn’t like the color tone. Other than that I have many dumb white LEDs controlled by other smart switches.
@johnzanussi
I’ve been searching for how I can link multiple Fibaro controllers together in Smart Things and found this post from 2015.
Do you know if there has been a smart app developed?
Thanks in advance
