Hello
I am not able to connect my Samsung split air conditioner having model number AR18AY5YBWK with Smart Things app. Can someone help me please
Hey there! @KRajesh69, Welcome to the Community! Thank you for providing me with the model code for the device you are attempting to onboard into the Smart Things Application.
Unfortunately, AR18AY5YBWK Air Condition is not Smart WiFi embedded and it is NOT able to be used with the Smart Things Application. I’ve included a screenshot of the Model’s specs below.
I would recommend searching the smart things application using the (+) Add a Device > by device type > ‘Air conditioners’ to locate compatible models that are able to be on-boarded to the Smart Things Application. You can also search by specific model codes if you would like to check if a specific model appears in the Smart Things Application.
I hope this message finds you well!
^SamsungZell
