Hi, thank you very much for your quick answers!
@JDRoberts:
- the sensor is new and the battery is the same, I’ll try that and update.
- as I test this, the sensor is located less than 10cm away from the coordinator.
- tried the setup in different location (work/home) without any change in results.
- yes I meant the 357 Telegesis USB stick, I cant find the version details you mentioned, mine is ETRX375USB firmware R308. Again, the distance is minor so I would eliminate this cause.
@JohnR:
- yes, setting up the dongle as coordinatior and I want the sensor to join its network. I don’t have the SmartThings hub.
- I determine that parsing the at-commands prompts I get in the terminal. I do that together with Telegesis support, however we can’t point the reason yet :/.
Some of the prompts I get:
SED:000D6F0004058626,8D1E,-37,FF
RX:000D6F0004058626,8D1E,0000,00,00,0013,0C:&o
SED:000D6F0004058626,B640,-28,FF
RX:000D6F0004058626,B640,0000,00,00,0013,0C:@&o
SED:000D6F0004058626,56A9,-28,FF
RX:000D6F0004058626,56A9,0000,00,00,0013,0C:V&o
SED:000D6F0004058626,6409,-28,FF
RX:000D6F0004058626,6409,0000,00,00,0013,0C:<98><09>d&<86><05><04><00>o<0D><00><80>
SED:000D6F0004058626,D9D3,-30,FF
RX:000D6F0004058626,D9D3,0000,00,00,0013,0C:<99><3F><3F>&<86><05><04><00>o<0D><00><80>
SED:000D6F0004058626,4240,-27,FF
RX:000D6F0004058626,4240,0000,00,00,0013,0C:<3F>@B&<86><05><04><00>o<0D><00><80>
SED:000D6F0004058626,E91B,-45,FF
RX:000D6F0004058626,E91B,0000,00,00,0013,0C:<9B><1B><3F>&<86><05><04><00>o<0D><00><80>
SED:000D6F0004058626,9850,-35,FF
RX:000D6F0004058626,9850,0000,00,00,0013,0C:<3F>P<98>&<86><05><04><00>o<0D><00><80>
