Samsung FlexWash 6-cu ft High Efficiency Front-Load Washer - WV60M9900AV
Samsung FlexDry 7.5-cu ft Gas Dryer - DVG60M9900V
Can someone confirm if this is compatible with SmartThings? If so, will it work on the classic app?
Also - do I need the Samsung USB dongle? Does it connect over Wi-Fi or Ethernet?
If I pair it with the connect app - can I use it with the classic app?
Any problems with using the classic and new app simultaneously? So use the new app (with the same account) for the washer/dryer and use the old app for everything else?
Sorry to revive this topic, but I need a new gas dryer and looking to see if this will work before I buy.
Once I get it setup through Samsung Connect, will the object appear in SmartThings graph IDE? All I really care about is when the cycle completes, I really don’t care about starting it or stopping it or anything else. All I want to know is, is the object addressable in IDE, and if so, what attributes show up for it. Most of my automation is done in WebCoRE and as long as I can read attributes off IDE, it will meet my needs.
