Cory_Booth
(Cory Booth)
1
[EDIT] May have found it: smartthings edge:drivers:switch
This did do the trick and I’m good to go…
Anyone know the command (or is there one) to change an edge driver associated with a device using the “Command Line Tool”?
I have a couple of GE Motion Switches - all same Device ID
One works, the others do not.
The one that works is using a different driver.
I cannot use the App as I cannot “connect” to the non-working devices.
But I can see the driver and the associations using the command-line tool.
Is there a command to manually switch the driver from command-line?
Also - it would seem anything tagged with “-assoc” doesn’t “connect”
Is there any significance with this “tag”
The API Browser created by @TAustin also has the ability to change drivers and is a little more user friendly.
