Combining multiple lightbulbs to act as 1
Ok newbie question I have been looking everywhere (because I hate asking newbie questions) but everything I find is outdated. The Big Switch, long press to combine, etc. I just got my first lightbulbs and my light needs 2 of them to work so how can I turn them on and off in the app with the push of 1 button? I have them automated to come on when we come home but I want to be able to turn them off without switching the the light switch.
Again sorry for the probably very easy question. I have had smartthing for a couple months now but everything has been garage doors, ecobee, and front door locks. this is my first attempt at lighting.
I use an app called dim with me. It controls 2 smart bulbs that are in the same fixture.
This app + virtual dimmer gives me one switch/dimmer that will control the 2 bulbs together.
You can do this with the smartapp Smart Lighting.
Shot, just realized you want to do it with an app button.
I think you can do this with a routine.
Take a look at this device handler for a Minimote $19.95 at
http://smile.amazon.com/Aeon-Labs-DSA03202-v1-Minimote/dp/B00KU7ERAW/ref=sr_1_1?ie=UTF8&qid=1459610291&sr=8-1&keywords=Minimote
This will give you virtual buttons that you can press to control things from your phone or Minimote.
You will also need a smart app to tell what the buttons do. You can use Button Controller +
Or the more powerful Rule Machine
This might even work without actually having a Minimote and just use your phone as the controller.
thank you so much the Dim with me app worked perfectly. I knew there should be an easy way to do this. I think I am going to buy light switches next time so I don’t have this problem or the bigger problem is my 2 year old likes to turn light switches on and off so I am sure this switch will be off when I really want it on.
Create a virtual switch. Use either rule machine or smart lighting and create a rule controlling both bulbs and the virtual switch as the trigger.
if you use Philips Hue the new Hue (Re-Connect) app includes Scenes and Groups for doing this.
