For a few of my Z-Wave Plus switches, when viewing device info in the CLI, I am not getting a Network ID. Any idea why?
Attached is a screenshot of one of many that do not have a Network ID entry:
Attached is another that does:
Hi, @Skates
The first device is Groovy-based, that’s why its type is “DTH”, that device type doesn’t support those properties.
The second one uses a driver, which has those properties as part of its metadata, that’s why the actual device type (Z-Wave) is specified in “type”.
By the way, that info from this device type can be seen in the IDE.
Edge-based devices aren’t supported there.
go to “My Locations” in IDE and tap on the name of your location… then check to see if your devices appear
That worked! Thank you!
