Changing z-wave parameters not posible anymore?
Hello,
I have a SmartThings hub V2 and I wanted to change the parameters for a Fibaro relay, like I used to do before. This operation it was done (back in the days) with the Z-Wave Tweaker Utility.
Now it doesn’t work anymore.
Is there any other way to change Z-Wave parameters?
Thank you.
Yes there is, thanks to one of our outstanding community developers. :smiling_face_with_sunglasses:
There is a custom edge driver which works in a very similar way to the old Zwave Tweaker.
Hi @JDRoberts
I installed the drivers.
Can U tell me what to do next? I tried to approach in edit device to assign the new driver to the device, but I could find any new drivers in the list like I used to do with Z-Wave Tweaker.
Thank U very much.
You can ask your questions about the zwave configuration tool in the topic about it and someone should be able to help you there.
If you’re trying to use the IDE to change drivers, you won’t be able to—the IDE is for the old architecture only.
Instead, see the community FAQ on edge for instructions on how to change from one edge driver to another. Specifically point 2 in the FAQ.
FAQ: I have no idea what Edge is. Is that a new developer tool? (2022)
