GRClark
(Gene Clark)
July 11, 2018, 9:27pm
1
I’m using Aeotec Multisensor 6’s using the custom handler recommended by Aeotec shown as “Aeon Multisensor 6 (Advanced)”. In the main icon view it shows temperature and motion icon. The issue is it doesn’t actually reflect whether there’s motion or not as it always stays the same. However it does change background color based on temperature. I’m wondering if it’s possible to set background to blue with motion, white when there isn’t any motion.
Here’s the main view:
Device page view:
Here’s the handler community post:
I know there already is some community code for this device, but I had to add my little twist to it. Some time ago I got pretty frustrated with the configuration and battery life on this device. I went about heavily optimizing this handler to make things simpler and squeeze some extra juice out of this device. I am not sure by how much, but these settings should make a difference in battery life. It has been sitting in my IDE collecting dust but wanted to make it available in case some are interested. It has some remnants of the official handler as well as so thanks to @Robert_Vandervoort and others that have worked on it.
This device has 3 different firmware versions that act a little differently which made writing code for this thing a beast, but I think I have everything working for 1.…
GitHub handler:
* Aeon Multisensor 6 (Advanced)
* github: Eric Maycock (erocm123)
* Date: 2020-08-10
* Copyright Eric Maycock
* Code has elements from other community sources @CyrilPeponnet, @Robert_Vandervoort. Greatly reworked and
* optimized for improved battery life (hopefully) :) and ease of advanced configuration. I tried to get it
* as feature rich as possible.
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
This file has been truncated. show original
@erocm1231
