Centralite Water Sensors 3315 with ST
Hoping to get help here. I have 12 Centralite/Ezlo Leak Sensors #3315 and all are stating it needs updates. But when I do this, nothing happens. Some are reporting fine with Temps and battery levels, while others show 100% battery and no temp.
I think it needs an updated driver. Does anyone have recommendations where I can get drivers for the Centralite Leak Sensors? Really regretting buying so many of these now.
This is where I purchased it from: Centralite by Ezlo Water Sensor - Monitors Your Whole Home for Leaks - Detects Water Leaks in a Kitchen, Bathroom, Basement or Laundry Room - Zigbee - Amazon.com
They are supported in the standard drivers.
They support over the air updates. Make sure updates are enabled, select your hub, settings, device firmware updates, automatic.
If they are not working remove device then add device, partner devices, centralite, moisture sensor.
https://blog.ezlo.com/centralite-water-leak-sensor/
Thank you. Yes hub set for auto but it just won’t update. I’ll try to remove an install again. Thanks again.
That’s great to hear! It makes sense auto but it just won’t update. I’ll try to remove an install again.
