Hello. New user of SmartThings, and new to this excellent Forum.
I have the three unit SmartThings Hub and Mesh Wifi system.
Problem: I cannot successfully add any devices. I am starting with supported devices namely Leviton Z wave wall switches, Jasco Z wave switches, Intermatic modules etc. They are not automatically found, nor can I successfully add them manually.
I suspect I am doing something wrong at a very basic level.
My Arlo camera hub installed easily and automatically, but it is connected directly to my router.
Following the instructions on SmartThings, I am not even sure I am in pairing mode. (I’ll limit this to the Leviton switches for now, for simplicity).
Yes. Have tried all the different Leviton options just to be thorough.
So the Hub’s green light should flash as soon as I select “add a new device”?
Additionally, just to be clear I am looking at the remote hub closest to the switch (~10’), not the hub hooked up directly to my router.
Thanks.
RBoy
6
If you have multiple hubs you may want to check that you’re putting the correct hub in pairing mode from your ST app (I would say use the ST Classic app, select your location and then try to add a device to it). Like Jimmy said, when in pairing mode it should start flashing the light
Sorry, I don’t see anywhere to specify which Hub I want to connect to??
RBoy
10
Click the Last tab, bottom right. Then on top you can select which “Location” you want to use. You should see all your locations here. Each location should have one hub. If you don’t see it then the hubs weren’t registered to your ID properly.
Once your location is selected you can then go to the Home/Things page and tap on + to add a new device.
If the switch was on Homeseer, you need to exclude it first. Then you can pair it. you can exclude via Homeseer or SmartThings. Https://support.smartthings.com has help articles on exclusion.
