Can you add drivers for ESPhome devices?
It is possible, but why would you mind?
If you are using esphome, probably, your device is fully integrated with Home Assistant.
yes, its possible, The @EverythingSmartHome EP1 uses an ESPhome chip I believe and it has a SmartThings Driver.
Yes @Ibrahim_Celik, see Announcement - ESPHome for SmartThings
Correct Jimmy, see Announcement - ESPHome for SmartThings
Hi @w35l3y, many of us do not use Home Assistant but would like to use the innovative devices developed using ESPHome and would like to have the capabilities to build our own devices using ESPHome.
See Announcement - ESPHome for SmartThings
Many Thanks Tim
Developed without using of home assistant?
Yes. ESPHome Standalone plus SmartThings with an edge driver which communicates with the device via the ESPHome Native API :sunglasses:
