I have a GE fan switch that I can not remove. I choose the device, click edit, then remove device and it loops back to the same screen. Any ideas on how to remove it?
I want to remove and re-add if with the Edge driver.
Is it a Z-Wave device? If so, put your hub in exclusion mode and then put the device in pairing mode. It should get deleted.
Yes. Thank you.
I was able to exclude it and even add it again with the Edge driver. But, the original device still shows in the app as offline.
Easiest way is to use the API Browser+ to list your devices, select the one not running the Edge driver and delete it.
Thank you! That worked to remove the stuck switch.
