In Cloudwatch found the request but there is no token provided. I can see in my Oath2 service that ST is calling for the refresh at the correct specified intervals. (For simplicity of testing, expires is set to 600 to monitor ST is alive). Also for simplicity, the schema connector Webhook is pointing to the same Oauth2 token endpoint and there can see the authentication part is included in the Webhook call.
2019-08-02T07:10:59.059Z ddb52abf-9c44-421e-be30-a3e9366d7fb8 INFO
“headers”: {
“schema”: “st-schema”,
“version”: “1.0”,
“interactionType”: “discoveryRequest”,
“requestId”: “0b397e6a-ce66-4a2b-9da0-7a5665ae8585”
According to the docs,
there should be a section:
“authentication”: {
“tokenType”: “Bearer”,
“token”: “token received during oauth from partner”
