Bug in Matter Scenes and Groups cluster library API v10 and v11
There is a weird bug present in multiple generated clusters with request/response commands. At least Groups and Scenes.
When building a StoreScene request command, it looks like the library is trying to build a response instead of a request. I can imagine where the error comes from since both request and response share the same command ID (0x04) and the library might be mixing them up somewhere.
This line:
local request = clusters.Scenes.server.commands.StoreScene(device, endpoint_id, 0, 1)
Results in this error:
“[string “st/matter/generated/zap_clusters/Scenes/clien…”]:74: Expecting Uint8 (0x04) for “Uint8” received Uint16: \x00\x00”
The first param is the group ID, which is indeed a Uint16, yet it is trying to validate it as a Uint8 (like if it was the first param of the StoreSceneResponse which is a Uint8).
In fact, if you build that param and force it as Uint8 creating the data type, it will validate. Then, if you send that request… it actually recognises it as a StoreSceneResponse instead of the expected StoreScene command:
sending InteractionRequest: <InteractionRequest || type: INVOKE, info_blocks: [<InteractionInfoBlock || endpoint: 0x01, cluster: Scenes, command: StoreSceneResponse, data: Structure: {groupid: \x00, sceneid: \x01, }>]>
Edit: The same happens with Groups commands like RemoveGroup, it will complain about the group ID data type because it does not match the RemoveGroupResponse fields.
By the way, given the API now supports scenes and groups, what is the correct way to send a groupcast message to, let’s say, recall a group scene? I believe that’s not implemented at the moment, right?
The bug is still present in API v11 (FW 54.x beta), so the new cluster Scenes Management cannot be used to store scenes. Not that there is any compliant device in the market yet but it’s something to fix.
"[string "st/matter/generated/zap_clusters/ScenesManage..."]:74: Expecting Uint8 (0x04) for "Uint8" received Uint16: \x00\x00"
Hi, @mocelet
Sorry for the delay. The engineering team confirmed sending groupcast messages is not supported yet.
Also, they will look into the issue you reported, in case we need more information or get any feedback, we’ll let you know.
Hi, @mocelet
Sorry for the delay. This issue was solved back in October and should ve available since v13 from the SmartThings Lua libraries.
Please let us know if you have any remaining issue with this.
Thanks @nayelyz , looks like the request building functions work now so I’m marking it as solved.
Hope SmartThings implements the missing group management pieces eventually to allow groupcast, otherwise groups and group scenes can’t be used.
