There is a bug in the new combined widget. It is very cool to have a more compact UI. Just a small issue when making one of the two not-visible. It disables the entire widget instead of just one of the capabilities. As an example, I created an example that disables the colorControl when a light is switched off.
Can you share your profile’s configuration, please? I created a test but the tiles for colorControl and colorTemperature didn’t merge, I guess it depends on the used caps or maybe the category…
ok, thank you for the info, it seems the combination of these two capabilities in a single tile is not supported in every device, I had to use another one to see it.
Anyway, as I was able to reproduce it in one, I’ll report it to the team.
@nayelyz I have another bug related to this new widget. It only updates the current color swatch if the color is set with setHue and setSaturation. Using the combined setColor is not changing the color in the UI. Still love the new widget though. Much cleaner.
