I’m having trouble with a color control tile. Below is the code for the tile and the setColor command. After publishing the device handler, I pick a color off the control and it logs…
Setting color to: [red:255, hex:#FFFFFF, blue:255, saturation:0.0, hue:0.0, green:255, alpha:1.0]
This is regardless of the color I choose. Then after that initial one, it no longer calls setColor unless I re-publish the device handler.
Ok, I think I see what’s going on now. There is also a slider below the ring which has to be moved up. Kind of a clunky control in my opinion. Is there a different option besides having it in a multiattribute tile?
