Breaker switch: z wave or Zigbee
I have a ductless air conditioner in an office (I live in Texas = hot).  It maxes out at 230 volts, uses 12 AMPs, 1920 watts, and has a minimum circuit ampacity (MCA) of 16. Is there a way I can cut or supply power to the unit via smartthings?  Obviously, the unit isn’t created with built-in zwave (or other) compatibility. Perhaps there is an existing z-wave or zigbee breaker where I could install it in the breaker box?  Maybe there’s a better way or alternative so that I can turn the unit either on or off remotely?
Any advice would be appreciated.  Thanks.
I think that such a thing exists, but (a) you’re not going to like how much it would cost, and (b) good luck finding someone to install it.
But I did find this:
http://static.schneider-electric.us/docs/Advanced%20Products/Efficient%20Homes/S1A90299_en.pdf
Will something like this work?
http://store.homeseer.com/store/Intermatic-CA3750-Z-Wave-Contactor-Module-P407.aspx
Yes… that would work, I believe.  Thanks ReyM.  I will look into ordering this.
I can’t remember where I saw it but I came across a Zigbee (or might have been Z-wave) IR blaster that you might be able to use to control the A/c. Different approach but I think it would achieve the same result and probably the type of thing I will need to use. Here is Australia it is not common to have ducted air conditioning vs a split system.
