Ok has anyone ever suspected a hub issue before? After constant issues trying to pair devices to this hub at my mothers house I tried pairing another device the IRIS Centralite keypad, same problem as I was facing with the Bosch sensor, gets detected and shows up as a “Thing” every time I pair it but never responds or works even after manually assigning the device handler. I took the two Centralite keypads and the Bosch PIR sensor to my own hub, and guess what same exact device drivers and had no problems pairing either device with my hub. So I suspect the issue is related to the remote hub, both hubs are v2’s running the exact firmware. Just was wondering if anyone had a hub go bad or corrupt before. Also something was odd with this remote hub, when I would login to my IDE page and view this hubs location and then get details about the hub I would be missing the view utilities menu. I just noticed this the other day cause it said this hub had Zigbee OTA disabled but my main hub doesn’t. Not that I suspect this is an issue but sure want to be able to push out firmware updates to my zigbee devices if I can. Going to ring Smarthings support, don’t expect much help from them, might have to see if they can switch out the hub for me or offer other suggestions. Just wondering if anyone has seen this before?
I’m sure this has been asked and answered many times but I’m still having an issue finding a definitive answer so I’m hoping someone here can shed some light.
My understanding is these Bosch Motion Sensors (ISW-ZPR1-WP13) work on about a 4 minute cycle.
- Detect Motion
- State = Active
- State = Inactive
- Sleeps ~ 4 Minutes
Is it true that while the motion sensor is in its “sleep state” its not going to detect any motion and the state will remain inactive?
What I haven’t been able to determine is what happens after the 4 minutes? Does the motions sensor continue “detecting” until it detects motion again or does it go back into a sleep state even if it doesn’t detect motion.
Thanks, Glenn
I have a couple of these motion sensors. I have used the “tomasaxerot” DH since it was new. Eventually I had to disable it because it kept on triggering for no apparent reason. It was sitting on a stationary shelf about 6" from the front edge of the shelf so there would be no way that my 3 small dachshunds would set it off. I do have 2 ceiling fans within range. There are also forced heat and air ducts in the ceiling. I am using a V2 hub and the classic app. The temperature sensor works, but I think it needs an offset temperature adjustment. I think it reads a bit “warm”.
Is it possible for either the ceiling fans or the forced heat and air conditioning to trigger these sensors?
I have had mines connected for a year now and I have two questions. Is this sensor still only compatible with the smartthings classic app. Anytime I try to connect using the newer app it says can’t connect. Also the batter life still says 100% after 1 year. Is the battery percentage accurate?
I have two sensors and for the life of me can’t get either to work. Relatively newbie for smartthings but generally tech savy. Have done certain work-arounds with other sensors but can’t get these [Bosch Motion Sensors (ISW-ZPR1-WP13)] to pair. Got the handler from here: https://raw.githubusercontent.com/tomasaxerot/SmartThings/master/devicetypes/tomasaxerot/bosch-motion-detector.src/bosch-motion-detector.groovy
Restarted hub several times, repeated step 7 maybe 10 times on each - no luck. Any more tips or alternative work-arounds?
My Bosch motion detector detects motion every 3 minutes, always detects it, sleep or not
Mines shows up in SmartThings classic and regular. Works as intended. If I go into details on regular app, it won’t show me most info, but on classic it shoes current temp, etc. Seems to work fine
I have been using several of these sensors with ST for three years. I used the device handler. They work great, except the battery life indicator always showed 100%. To get battery life indicator finally working, all I had to do was to change sensor type to smartsense motion sensor (in place of bosch motion sensor). That simple change made the battery life indicator work. Yeah–after three years I finally git it working.
Bumping this old thread – is there an edge driver available for this device?
EDIT: looking in the soon-to-be-deprecated IDE, I see that my device is using the SmartSense Motion Sensor running locally. So does this mean I am good to go and will be migrated automagically to an edge driver? (I don’t think I am running the edge driver yet because when I go into the device in the app and click the three dots, I don’t see a ‘driver’ option)
Hi @jamclam
This driver works. Only the battery information is not confirmes if works fine, but it should work
Thanks for the quick reply!
Could you clarify – is that part of the stock drivers, or is that a custom driver, and if so, which channel should I add? (I read through the thread you linked to, but it wasn’t clear to me which driver channel to add)
I have 5 of these motion sensors installed around the house. In the last 2 days all of them stopped working. I remove them and reset them and tried to add them back but the ST hub does not recognize them. Does anyone have the same issue?
Same here. Any solutions?
I have 10 can not pair them back even with 3 bets channels of edge drivers
Hi @OCSMITH @field210 @Carlos_Jato
These are the models that are in the Zigbee Motion Sensor Mc controller.
If once the driver is installed in your Hub they do not pair with it, it is possible that your model is different or you have to delete the custom DTH or comment with // the fingerprints.
- id: "Bosch-RFDL-ZB-MS-Motion"
deviceLabel: Bosch Motion Sensor
manufacturer: Bosch
model: RFDL-ZB-MS
deviceProfileName: motion-temp-battery
- id: "Bosch-RFPR-ZB-MS-Motion"
manufacturer: Bosch
model: RFPR-ZB-MS
- id: "Bosch-RFPR-ZB-Motion"
manufacturer: Bosch
model: RFPR-ZB
- id: "Bosch-ISW-ZPR1-WP13-Motion"
manufacturer: Bosch
model: ISW-ZPR1-WP13
Thanks for all your work, I have no device handlers… started this with new account after my hub went offline and could not get it back online because of Sonos Speakers…l think
Go down to:
“This is a link to my Edge drivers Shared Channel”
Hi @OCSMITH
Install this edge driver from my shared channel and try to pair device
2022-10-30T12:33:20.683132801
https://api.smartthings.com/invitation-web/accept?id=6b68563b-1905-4654-8d2b-e677a2997424
Thanks for giving us a hand @Mariano_Colmenarejo
I have the same model listed in your driver (see pic)
I followed the steps, installed your beta driver in the hub (in the phone app shows as being installed).
Then I restarted the app and rebooted the hub to be safe.
Next I went into add a device and started searching for devices.
Then I did reset the sensor and put it in pairing mode (blinking three times every 5 secs or so)
Nothing happens.
I did this three times to make sure I did not miss anything.
like @OCSMITH I also come from a clean account and a formatted the hub. no handlers in the IDE platform. I have been trying to add them and tried everything I don’t have any handlers and cannot add any new ones so not sure how to add the “//”
De que parte de Madrid eres?
@Carlos_Jato
Install Zigbee Thing Mc driver from my Channel and try to pair device to see the complete fingerprints
