As you pointed out, https://Account.smartthings.com is the official link and will redirect to your correct shard.
I think I figured out how to do the above. Testing now.
Thank You for this. This saved my automation.
back to IFTTT
Thank you for your explainations. The Blink issue forced me to look at IFTTT, which I didn’t fully understand. Your short explainations helped me walk through my first applets. I’m able to trigger the applets using a virtual switch. Thanks again!
Bob D.
The bad thing is that Blink’s IFTTT do not support my region (SG), so i have no any alternative way to connect to SmartThings.
if anyone wants to go complain in person
For those looking to meet the team behind this award-winning product, Blink will be at CES Unveiled on January 7 and CES 2018 from January 9 to January 12 at Booth #42535 in the Smart Home section of the Sands Expo, Level 2, Halls A-D.
Maybe “make a friendly request in person” would be a better term.
Is there a way to arm/disarm single camera’s. That and the ability to tap into the motion sensor on the camera was what I was using RBoy for. Looks like the latter is solved, but not sure about the former.
Not with IFTTT.
You can’t arm/disarm individual cameras, but you can still use them as motion sensors in ST though it is a bit of work.
How do I get my Santa hat tassel to go the other way?
I was using my 3 Blink cameras as motion detectors for my smart Things. Is there anyway for me to set that up since Blink has been rendered useless?
If you have an android device you can use Tasker, Autonotification and Sharptools with a simulated motion sensor device in Smartthings for your automations. You can also use Ifttt with Blink as the “This” and Smartthings as the “That.”
I’ve left reviews on Amazon and Tweeted them to make my displeasure known. Everyone needs to do the same. If you tweet them, make sure not to start the Tweet with @Blinkforhome. That would make it so that only they can see the tweet.
Type your response ABOVE THIS LINE to reply
Re: [SmartThings Community] [Devices & Integrations] Blink support discontinued!
Blink | Dec 20, 2017 02:23PM UTC
Thank you for your email. We have received your message and will respond to you as soon as possible.
Thanks in advance for your patience and support.
This message was sent to smartthings+bd2be70bdbe018b7d09773a67f8d5a7b@discoursemail.com in reference to Case #84535.
[[a2f4c5299557b50bd2f1702a4ec43bf45db380ef-1105762274]]
