So I’ve taken System48’s device handler and I’m trying to edit the code so a smart lighting routine can turn on the switch on/off.
It currently only lets you turn the fan on by manualy pressing the switch and it looks like no information from SL is getting to the device.
Any help?
- Haiku Fan Control
preferences {
input(“devname”, “text”, title: “Device Name”, description: “The devices name”,required:true)
input(“destIp”, “text”, title: “IP”, description: “The device IP”,required:true)
metadata {
definition (name: “Haiku Fan Control”, namespace: “System48/Smartthings/Haiku”, author: “System48”) {
capability "Switch"
capability "Switch Level"
command "fanon"
command "fanoff"
command "setfanlevel"
command "lighton"
command "lightoff"
command “setlightlevel”
simulator {
// TODO-: define status and reply messages here
tiles {
standardTile("fan", "device.fan", width: 1, height: 1, canChangeIcon: false, canChangeBackground: true) {
state "fanon", label: 'On', action:"fanoff", backgroundColor: "#79b821", icon:"st.Lighting.light24"
state "fanoff", label: 'Off', action:"fanon", backgroundColor: "#ffffff", icon:"st.Lighting.light24"
controlTile("fanlevel", "device.fanlevel", "slider", height: 1, width: 2, inactiveLabel: false, range: "(0..7)") {
state "fanlevel", label: '${name}', action:"setfanlevel"
standardTile("light", "device.light", width: 1, height: 1, canChangeIcon: false, canChangeBackground: true) {
state "lighton", label: 'On', action:"lightoff", backgroundColor: "#79b821", icon:"st.Lighting.light13"
state "lightoff", label: 'Off', action:"lighton", backgroundColor: "#ffffff", icon:"st.Lighting.light13"
controlTile("lightlevel", "device.lightlevel", "slider", height: 1, width: 2, inactiveLabel: false, range: "(0..16)") {
state "lightlevel", label: '${name}', action:"setlightlevel"
main "fan"
details(["fan","fanlevel","light","lightlevel"])
log.debug “Parsing ‘${description}’”
def fanon() {
sendEvent(name: “fan”, value: ‘on’)
request("<" + devname+ “;FAN;PWR;ON>”)
def fanoff() {
sendEvent(name: “fan”, value: ‘off’)
request("<" + devname + “;FAN;PWR;OFF>”)
def setfanlevel(val) {
if (val==0) {
sendEvent(name: “fan”, value: “off” )
} else {
sendEvent(name: “fan”, value: “on” )
sendEvent(name: “fanlevel”, value: val)
request("<" + devname + “;FAN;SPD;SET;” + val + “>”)
def lighton() {
sendEvent(name: “light”, value: ‘lighton’)
request("<" + devname + “;LIGHT;PWR;ON>”)
def lightoff() {
sendEvent(name: “light”, value: ‘lightoff’)
request("<" + devname + “;LIGHT;PWR;OFF>”)
def setlightlevel(val) {
if (val==0) {
sendEvent(name: “light”, value: “lightoff”)
} else {
sendEvent(name: “light”, value: “lighton”)
sendEvent(name: “lightlevel”, value: val)
request("<" + devname + “;LIGHT;LEVEL;SET;” + val + “>”)
def request(body) {
def hosthex = convertIPtoHex(destIp)
def porthex = convertPortToHex(31415)
device.deviceNetworkId = "$hosthex:$porthex"
def cmds = []
def hubAction = new physicalgraph.device.HubAction(body,physicalgraph.device.Protocol.LAN)
cmds << hubAction
log.debug cmds
cmds
private String convertIPtoHex(ipAddress) {
String hex = ipAddress.tokenize( ‘.’ ).collect { String.format( ‘%02X’, it.toInteger() ) }.join()
return hex
private String convertPortToHex(port) {
String hexport = port.toString().format( ‘%04X’, port.toInteger() )
return hexport
