HI @deano12, I have update the Fix with a great service, try to check the code in https://github.com/SmartThingsUle/DLNA-PLAYER/blob/master/Sonos_Weather_Forecast_External_TTS.groovy
Having issues with the TTS function. I can play Internet radio and dogs barking. When I go to do any of the TTS or Sonos Weather - It isnt playing the file. It lists the file which I can play on my computer.
From what I read, the ST’s TTS is back up and running? Do we still need to use an external one? Could that be causing it? if I have it enabled?
Also - note the second log .
Thoughts?
b6b79cca-7593-4ace-b436-eac0aa2b641f 12:35:16 PM: trace Skipping event generation for sound file http://www.translate.google.com/translate_tts?tl=en&client=t&q=The%20current%20temperature%20is%202%20degrees.%20Today%27s%20forecast%20is%20Cloudy%20skies.%20High%203%20degrees.%20Win&sf=//s3.amazonaws.com/smartapp-&ts=1450287296774%20 b6b79cca-7593-4ace-b436-eac0aa2b641f 12:34:59 PM: error org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 2766; The reference to entity "client" must end with the ';' delimiter. @ line 197 b92b4906-7483-40dd-95c7-bba51cfc3005 12:34:56 PM: trace uri: http://www.translate.google.com/translate_tts?tl=en&client=t&q=The%20current%20temperature%20is%202%20degrees.%20Today%27s%20forecast%20is%20Cloudy%20skies.%20High%203%20degrees.%20Win&sf=//s3.amazonaws.com/smartapp- b92b4906-7483-40dd-95c7-bba51cfc3005 12:34:56 PM: trace cleanUri(x-rincon-mp3radio://www.translate.google.com/translate_tts?tl=en&client=t&q=The%20current%20temperature%20is%202%20degrees.%20Today%27s%20forecast%20is%20Cloudy%20skies.%20High%203%20degrees.%20Win&sf=//s3.amazonaws.com/smartapp-,WD TV) b92b4906-7483-40dd-95c7-bba51cfc3005 12:34:56 PM: trace state.sound [uri:x-rincon-mp3radio://www.translate.google.com/translate_tts?tl=en&client=t&q=The%20current%20temperature%20is%202%20degrees.%20Today%27s%20forecast%20is%20Cloudy%20skies.%20High%203%20degrees.%20Win&sf=//s3.amazonaws.com/smartapp-, duration:13] b92b4906-7483-40dd-95c7-bba51cfc3005 12:34:56 PM: error java.lang.reflect.UndeclaredThrowableException b92b4906-7483-40dd-95c7-bba51cfc3005 12:34:56 PM: trace normalize
Hi I have added a new TTS engine, now You can use ivona TTS from Amazon. try it
