I’m not an expert here was hoping one of the forum members is. But from yours post to me it looks like its polling the crap out of the fan. I do see 1 transmit failures in yours as well. I have had 2 transmit failures which I then had to remove the device and replace it to get it working again.
From my naive look at the data the number of packets from the hub to my switch should be around the same as the number of packets from the switch to the fan. For me I see an order of magnitude more going from the switch to the fan. Just seems off to me but I’m not a zigbee guy so could be talking out my behind.
If it’s not the one that comes pre-installed in the fan already then no, I’d have to purchase it and install it. That was one of the sources of my confusion - I wasn’t sure if I needed to purchase the controller or not since I already had a wink-enabled fan. I assumed the controller would be the same.
Ok, i’m gonna assume you have the correct fan controller. Basically you need to install the DTH for the fan controller so it works in SmartThings. Think of a DTH as a driver for a video card or computer mouse. If you watch this video it should basically guide you thru all the steps. He’ll do a better job than i ever can. Go to 11:50 in the video, this is where the guy starts setup. https://youtu.be/lK_c4hXpQBs?t=691
However i want say that this video is old and is based on the first DTH but it will guide you on what you need to do. However, you should watch this other video on how to link Github to your SmartThings IDE
Posts still seem active, but I don’t see anything about getting this to be compatible with the new app. Primary question to that is I’d like to import into google home, but its only importing the devices that are in the new app. Is there a way to get devices from classic app or is anyone working to develop integration with the new app?
Integration with the new app works. I’ve been using it for a few days now and works with Google home. The link I posted above takes you to the new DTH.
Yea I agree. I’ve been using the old DTH and just switched over to the new one from Rafael and Google home integration has been restored, though I still needed to create a virtual switch for the light
Anybody have weird behavior with this device after a power outage? It’s happened twice to me. It becomes unresponsive to zigbee commands. The first time it fixed itself, this last time noting seems to bring it back.
In the past that is what caused my issues. If you search the thread you’ll see my posts. I fixed it a few times deleting the child devices and doing recreate process.
Also you could switch to the new device handler and fix it that way. See my post above yours. Super easy 5 minute fix.
I was able to reset it, and re-add it with the old DTH and worked fine.
[edit] Just removed and re-added with the new DTH. Seems simplier with only 2 parts, and I like that I can use a dimmer type command for the fan vs all those separate devices.
Thank you! This was super helpful and I was able to use it to add one of my fans to the hub.
Unfortunately, it won’t work with my second fan because while doing the install, I discovered that the wink antenna had actually been sliced during its original installation,… and while trying to splice it together myself, I ended up shorting out the controller -_-.
Hey i got Mines to work and then five minutes Later i tried turning on the fanlight and it says off-line  or Sylvania/Lightify led strips? If you do that might be it too. They are AWFUL repeaters and can cause mesh issues. Singled bulbs don’t repeat so they would be ok.
