I am looking to install a GE-ZWave Dimmer switch and looking to have 2 Phillips HUE lights to match the same DIM setting % on the switch. I also have the Hue Brudge linked to smartthings. Whats the best way to do this and possibly have the code run locally on the smartthings device?
webCoRE doesn’t run local. If you are using the official Hue integration then you can use the mirror functionality in Smartlighting and it will run local.
