Either version of the minimote is capable of doing an association Between 2 zwave classic devices In association group 1. However, association changed significantly with zwave plus, and the minimote is not the best way if either of the devices is zwave plus, and I don’t believe it will work at all if either of the devices is using S2 or S3 security.
So these days most people do it differently, by using the “Z wave Tweaker.“ This is a DTH which will expose all of the configurable parameters for any Z wave device and let you change them. That includes association.
So you use the web interface to your account, the IDE, to temporarily change the DTH of the trigger device to the zwave Tweaker. You make whatever changes you want to and they will be stored in the device itself. Then you change it back to its original DTH.
If you are Unfamiliar with the terminology and concepts of a DTH, see the following FAQ. Although the examples are from the classic app, the terminology and explanation and concepts still applies.
FAQ: An Overview of Using Custom Code in SmartThings (SmartThings Classic)
After you have read that, you can go to the thread on the Z wave Tweaker and get the code there that you will need:
