The easiest way to create zwave associations between devices in SmartThings?
Hello,
My goal is to find the simplest way to create associations between SmartThings Z-Wave devices (already added to a ST hub).
What is the easiest way that YOU found to create associations between Z-Wave devices? (that have multiple channel association groups, not only lifeline)
I heard that a better way to create associations between SmartThings Z-Wave devices is not via DH Z-Wave Tweaker but from another Z-Wave controller (like Vera, Zipatile, etc) added as a secondary controller to the ST(SmartThings). Or create associations between ST devices via Aeon Minimote…
I want to know what is the easiest way to create associations between ST Z-Wave devices, that YOU discover…
Thank you.
It varies based on the specific details. Most people will find that The tweaker is the easiest way to do it for mains powered devices.
Using the tweaker
All you have to do is use the IDE to change the device type handler of the trigger device to the tweaker, a very simple step.
Then go to the device in your things list, and you will immediately be able to set all parameters and all associations for that device.
Go back to the IDE, change the device type handler of the trigger device back to your every day DTH, and you are done. :smiling_face_with_sunglasses:
Fast, easy, does not require any other physical devices, does not require modifying your network in anyway. :+1:
The biggest drawback of the tweaker is that it doesn’t work with battery powered devices.
You also have to do each trigger device one at a time.
Using a minimote
If you have a minimote already on your network, it’s a good way to set a very simple association for a zwave classic device using Association Group 1.
Unfortunately, it is not going to work at all if you need to set an association for a different Association group, or if you need to set any additional parameters. :sad_but_relieved_face:
But if all you need is to, say, associate a zwave classic auxiliary switch with its master, you can definitely do that. You can also use it for a few battery powered devices, typically motion sensors. So it has its uses, but it is much much more limited than the tweaker.
Again, though, the minimote can only make associations in Association group one, and beginning with Z wave plus, association group one became reserved for the lifeline group. So the minimote is only useful for associating older devices.
Using another controller as a secondary
It’s possible to add a different zwave controller, such as Vera or a Leviton tabletop controller, to your smartthings network as a secondary, and then use its set up utilities. But this requires several steps and may or may not work well.
One) you have to buy the other controller unless you already have it
Two) you have to add the other controller to your network as a secondary. How difficult that will be depends on that particular device.
If you already had the controller on your network, you will have to remove it and add it again in order to get any new devices.
Three) once you have it on your network, it will now have access to the Z wave devices which were on your SmartThings network at the time that it joined. So now you can use its utilities to set up the associations. That means you will have to learn how they work if you don’t already know.
You may or may not have access to all association groups and to all parameters-- that just varies by controller. (The tweaker, in contrast, will always expose all association groups and all parameters for each device.)
One of the most challenging parts is that in some cases the devices in your things list will show up as a list on the new controller: but only by their Z wave ID. You may not see their name. This is true for both the trigger device and the target device.
However, there is one advantage to some other controllers: they will let you work directly from a full things list, so if you’re trying to associate many devices, it may indeed be faster than using the tweaker individually for each one.
For example, if you just installed four new virtual three ways, it might be faster to use a different controller’s utilities to set up all 4 associations. But then you may have to go into a different screen or utility to set the parameters, so if you also want to change any of those, such as changing the LED indicator light behavior or the ramp rate, then the tweaker might be faster.
So as far as which one is best, it really comes down to the details of what you are trying to do, whether you already own the other device that might be necessary, whether you are already familiar with the utilities for the other controller, and how much device information comes over when the secondary joins.
If you use the tweaker, you don’t have to learn a new system and you don’t have to buy any other devices. But if you are migrating from a different controller so that you already own it and you are already familiar with its utilities, that might feel more comfortable for you.
It’s really just a personal decision. :smiling_face_with_sunglasses:
BTW, if you are just looking at a screenshot of the vera association utility, it looks at first like it will be easier than the Tweaker. In practice, though, many people run into problems and the usual saying in the vera forum is that setting up associations is “clear as mud.”
For example, read the following 2017 thread from a Vera user who is just trying to set up three Leviton switches so they will be associated to each other.
http://forum.micasaverde.com/index.php?topic=52024.0
In spite of lots of help from other people, the poster has a great deal of difficulty getting it all to work as desired.
So just because another controller has an official association utility ( which smartthings does not) , it doesn’t necessarily mean it’s going to work any better than the tweaker will. :wink:
And of course another advantage of using the tweaker is that you will be able to come to this community if you run into any problems with it.
If you have some kind of hybrid vera/smartthings system you may find that people in neither forum are able to help you very much because of the complexity of your setup.
Can you tell us where you heard this? The tweaker is very popular, for all the reasons discussed above. :sunglasses:
I’ve used the Tweaker before to do this but I tried again yesterday and it did not work. It cannot find any existing associations and the new one that I try to make fails. AFAIK, there is nothing new about my Tweaker DTH or the devices themselves. Did new hub firmware break this?
Yes, it appears that they broke it in FW ver. 000.027.00009. I am unclear on whether this was intentional or not. See this issue for the Tweaker for more information and a work-around:
It would be really nice if it were fixed in a future FW update but I am not banking on it.
Tagging @Kianoosh_Karami
Yes, we should be releasing a new firmware this month that should contain the fix for this issue. We should be starting the beta release this week or early next week, so if you’d like to try it out, I can help you sign up for our beta release.
Great, thank you. I would like to try the beta release.
The fix for this issue has been released to all 2015 & 2018 SmartThings Hubs.
Confirmed that it now works again in FW 000.028.00011. Thank You!
Any idea when this firmware update will roll out to Samsung connect home devices? Or how to force it? I’m still on the older version (000.027.00010) it hasn’t updated for me.
Also in Samsung Connect Home and still shows firmware version.027
Cheers,
Richard
I am new to SmartThing and relatively new to Zwave. I got association to work years ago using the Aeon Minimote remote v1.0 (earlier version) with an Interlogic Simon XTI panel supplied by alarm.com. I am migrating and upgrading everything from alarm.com over to SmartThing. Can anyone confirm the following so I know what direction I should take going forward. (ps. So far, love that smartthing hub come with its own zwave excluding util on the hub)
  1. Do I add the Aeon Minimote into SmartThing just like another z-wave device
  2. Do I need the version 2 of the Minimote for association with SmartThing, or would version 1 (it has number on the top four button versus bunch of square shape. And version 1 only has a button say join)
  3. Can anyone post the step by step process and order on how to add in the controlling switch (it is Evolve), controlled switches, and the Minimote remote? I am assuming you first all three of them in but than what?
  4. As I state it before, the version of Minimote I have is version 1. The buttons its has say 1, 2, 3, 4, Device +, Device -, and Join (with a wifi like Logo). Which button do I used to add to SmartThing? Which button do I use for association?
Any feedback would be much much appreciated
