Does anyone know if Baldwin smart locks are compatible with Smart things? I shows they are Z-Wave Capable but when i go to add a smart lock on Smart Things Baldwin doesn’t show up as a brand to select.
Try adding it as a Z-Wave Lock or simply put the device in pairing mode and do a Scan Nearby.
Ah will try that tonight by adding as Z wave lock. I id try pairing mode and never picked up on any of the locks. This i was stuck because it has a ton of different brands except Baldwin.
I’ll try to press the A button and select Z wave lock. Thank you!
Baldwin is an upscale brand with the same parent company as Yale, so it might identify as a Yale lock.
In case anyone is still trying to do this, the Baldwin Estate Z-Wave locks are the same as the basic Kwikset touchscreen Z-Wave locks. I was able to add mine by going to add device, selecting Kwikset, then Z-Wave Lock (Not a specific model). SmartThings will prompt you to push the “A” buttton on the lock. Then just wait a few minutes.
If it doesn’t work the first time, factory reset the lock and let it do the “handing” process. Then add it to SmartThings before adding any codes to the lock.
