I have a routine set on my hub to unlock the back door - Yale connexis l1 if the wife comes home
i’ve set the routine settings
change the mode to - home
Unlock these doors - door selected
automatically perform - set to run when someone arrives - wife’s phone is chosen and mid week dates set
I also have dont automatically do this - home status set
nope missed the hub to away setting - so have set a routine to automatically set the hub to away after 3 mins if she leaves the house and makes sure tv is off and lights on system are off
still not really working the way i want it to - think it has only unlocked once since i had it setup
now i have another complication, I have added an echo to the system to do voice commands
all the commands and setups work fine except for the door
it says in Alexa app - smartthings routine - disabled because it contains devices unsupported by Alexa
I guess i cant have the routine to open door on arrival - which doesn’t really work, and have the Alexa open the door from voice
Once you have setup your routine you can configure it to activate automatically “when something turns on or off”
Configure the routine to run when your virtual switch turns on
Then, just tell Alexa to turn on that switch - that way “she” doesn’t know what devices she is controlling - she just thinks it’s a switch
