i want to place a pressure mat (connected to smatthings) under my computer chair so whenever i sit down, my phone will disconnect from my hearing aids, my computer will connect to my hearing aids, vise versa, is there a way to do it?
While the below topic is several years old, the premise is the same; connect a contact sensor supported by ST to the pressure mat.
How you connect/disconnect your hearing aids will depend on the capabilities of those devices.
another approach is if your monitor is on to measure the power from the computer/ monitor and perform logic from the smart plug power output.
of if there was a mouse with built-in smatthings that could connect/disconnect from pc/laptop whenever moved, or if hearing aids had a smartthings radio built-in to them
