I had 3 Arlo Pro 2 Cameras working Perfect with ST! A few months ago things started to go haywire with the Cameras and ST. I removed the Cameras from ST.
I tried to add them back and just couldn’t do it. I forgot about it till today and decided to remove all the Cameras from Arlo and I also unlinked them Arlo from ST.
I added the Cameras all back to Arlo, disarmed them and then went to ST Device Add. I clicked Arlo, gave ST the credentials for Arlo and it said it was added successfully. But I still don’t see any camera, don’t ever see any cameras to choose to add, nothing! I tried this multiple times deleting everything even the apps.
Is it just no longer possible to add the Arlo Cameras or is there a way to do this that I’m missing? I can’t believe the instructions are not listed how to do this? The instructions I’ve used don’t work.
Are the cameras suppose to show up in this page because they don’t? I click on Arlo at the top and then it takes me to the next screen where it asks me what room I want.
Have you checked the Groovy IDE website to see if any placeholders for the Arlo cameras are still listed as devices after you deleted them from the app? If so, delete then there too.
Thank you JKP, no I wasn’t logging in on that page. All my devices are now showing along with one hub. No cameras are showing. No Handlers. The only thing I see out of place is there are two entries for my iPhone in Devices.
That’s good that it didn’t leave any ghost device residue.
Another trick would be to power cycle the Arlo Base Station then once it’s back online in the Arlo app, go to the SmartThings app linked service for Arlo to see if that does anything.
Also, here is a massive thread that somewhere in it might lead you to a resolution. This thread is about when they changed the old ‘Arlo Connect’ linked service to the new ‘Arlo’ linked service.
Hi Usmcss
Did you ever find a solution to this issue?
I’m facing the same thing. My cameras where working fine in ST, but yesterday they started acting up, so I removed the link to my Arlo account from ST. Removing the link and adding it back has helped before. This time when I try to add them back by linking to Arlo, the cameras don’t show up in ST.
