Good afternoon!
According to the “Partners” SmartThings webpages, Arlo Essential is supported by SmartThings:
However, I have one issue with my two Arlo Essential Indoor Cameras (VMC2040 model): When I create ST Routines to trigger recording with them (when motion is detected), the cameras don’t record.
In contrast, I also have three Arlo Pro cameras connected to the Arlo hub (VMS4330 model), and everything works perfectly: The ST Routines I set up work perfectly, and the cameras record when motion is detected.
Can you help me understand if I may set up my Arlo Essential Indoor Cameras so that the routines record a clip when movement is detected? Or is this not possible with the Essential Indoor?
Thank you!
