Aqara Radiator Thermostat, ZigBee, Srts-A01
Because I have to order this thermostat in a country where retour options are more difficult, I would like to know if this is a plug and play tool.
I see Aquara in ST app: “New device/aquara/thermostat” but I want to be more convinced that it will work out of the box.
In case of emergency I coul also order an Aqara hub, but…
weird that Aqara doe not mention Smartthings: Radiator Thermostat E1 - Aqara
Edit…Not many reactions. If somebody has a working alternative…
The E1?
Yep e1 Thermostat
I do not want much. Only manually change them.
I prefer not using the Aqara hubs. I already have ST and Hue.
But also Google Nest
I had one for testing purposes and it worked as expected.
Forgot to mention: you need a SmartThings hub, of course.
Of course SmartThings hub.
So: just add “new device” , choose Aqara/thermostat, and working. Good news, Thanx.
