I’ve just received my new Aqara B1 curtain motor, I was able to pair it with my Smartthings Hub using @ ShinJjang device handler … but I can’t control it. Anyone is using it with Smartthings (without the Xiaomi HuB) ?
Second issue, from what I’ve seen (https://youtu.be/8hF62NwW4uQ?t=540) I should be able to pull the curtain and it will close/open automatically … again no luck.
Yes it does work when I press the button on the motor .
Update: Once connected to the Aqara Hub I was able to enable the “manual mode” with a gentle pull. I still can’t use it with Smartthings, or link the Mi Home or Aqara app with Google Home
