Apple Watch integration
I used to use the wonderful JSmartWatch app when I was out and about and didn’t have my iPhone with me, was great for running scenes and checking the status on things, but since the api change it’s no longer working. I used it daily too. Just wondering if there is anything else out there?
I know I can use Alexa but having rather than using your voice it was great to have the buttons to run scenes etc.
John.
There is a WatchOS SmartThings App it lets you run ‘Manually run routines’
It also supports notifications which you configure in routines.
The other way to see devices on your Apple Watch is in the Home App by connecting SmartThings to Google Home and then using a Starling Hub to bring them into Homekit. The lamps below are SmartThings plugs connected to a SmartThings hub in Homekit via Google and Starling Hub.
As you can see on my watch face I have my Aqara U200 door lock top right and Google Nest V3 Thermostat bottom right.
Edit: I tried JSmartWatch and it still works.
Does your phone need to be with you?
With the Apple Watch app your phone needs to be nearby by or it won’t work.
Yes because I have an Apple Watch 8 GPS so no cellular. Why?
That’s my point from my original post. You need the phone with you.
I have the 4g Apple Watch and it still needs to be with me.
You didn’t need that with the JSmart watch app.
yeah but my api changes every day now
