Apparently, latest WebCore update not possible from IDE
Hello. When I open the WebCore app from my android phone, I get a message that a newer version is available ( I have v0.3.10f and the newer version is v0.3.110) I tried to update from Repository, but none of the 4 apps appear on any column. What should I do to update WebCore in this case?
You can try…
First thing, you may want to open each smartapp in IDE and verify you have older code. Each should have the version near the top.
Logging out of your github account in IDE and reauthenticating that account. Then see if the update shows up.
Using community installer smartapp to update it. Requires you install that code if you don’t have it.
Manually updating the code for each smartapp in IDE using copy/paste.
